Drag racing wheels & tires photo thread
Touché, mon ami; or Tushy, mon cheri.
Ohhh if you were only a woman you'd be gettin' a PM.:ROFLMAO:
Decay
Astoria
OR
2019 widebody Redeye
#62
Forgestar 18X5 skinnies.
When they put the balancing weights on be sure they are not in the middle of the wheel if you have the big brakes.
At least on my car, I had to move them to the outer edge of the wheel. IMG_2918.JPG
Decay
Astoria
OR
#63
In IMG_2929.JPG between showers
555 Redeye
Fairborn
2022 SRT Jailbreak
#64
Currently; Billet Specialties 18 X 5 front wheels with Hoosier 28 X 4.5 - 18s and OE Demon wheels with MT 305 18s ET Street Rs on the rear. Will be going to the Billet Specialties 17 X 10 wheel that matches the front skinny with MT 315/50/17s for the rears. The fronts with the Hoosiers only weigh 26.4 lbs. Added 4/1/20: Got the matching billet rears mounted with the MT 315/50/17s. Now hoping there will be a 2020 season at my track.
20190711_203314.jpg 20200110_172713.jpg 20200319_214020.jpg 20200331_143138.jpg
555 Redeye
Fairborn
2022 SRT Jailbreak
#65
Wholeshot wheels custom 15x10 inch beadlock 14.5 lb rim,pro radial 315x15 lbs,billet specialties 17 x4.5 with hoosier 2.75x4.5 bias ply
I have the same Hossiers for the fronts. What psi are you running in them? Mine were installed at 38 psi and when I let the car down on one during the test fit, it looked kinda flat.
I don’t know about hoosier but I run my front MT at 90 psi
MOD EDIT: Confirmed, check sidewall Max Inflation pressure
yellow_hellcat
Lincoln
NE
My new setup for the spring! Racestar 17x9.5 and some P305/45R17 Mickey Thomson ET Street R's.
Decay
Astoria
OR
#68
YMMV
Morris Co
18 Charger HC
#69
For the guys running the race stars; you guys get any slippage between the rim & tire?
motorhead
Ottawa
2019 Challenger HC Widebody
#70
Seems very common. I am going to clean the paint off the barrel mounting surfaces a with an aggressive roloc disc and knurl that area with a chisel (?) before mounting my drag radials.
yellow_hellcat
Lincoln
NE
I don't have them mounted yet so slippage to report here!
BUT, I did take a look at the wheel and it appears the factory put a knurl on the wheel. Not sure if that is new or if it helps.
YMMV
Morris Co
18 Charger HC
#72
Wow! Ty for the heads up! I wonder when they made that running change. The last pair I bought was over a year ago for the Slomaro. Never really worried about tire slippage then since it doesn't make the type of power our H/Cs make.
motorhead
Ottawa
#73
Wild development. I just check the wheels I got late last year (and these were the newer widebody spec 17x11s) and they definitely didn't have it at the time; and there is no announcement on their website or FB about the change.
They do offer a "direct drill" option now, which may negate the need for a hub-centric ring kit.
motorhead
Ottawa
#74
Brand new 17x11s that don't have knurling, going on JLT's WB:
tkracing1
Bay Area
2017 challenger
#75
NJ_Redeye
Audubon
#76
Decay
Astoria
OR
#77
Looks good! Those should be sticky.
You know you've got some good shine on the car when you pick up the reflection of the rag on the ground!
Waxhaw
NC
2019 Challenger Hellcat Redeye
#78
That little bit of knurling is not enough to keep the tire from spinning on the rim. I had to take a dremel to mine and put a cross hatch pattern on the vertical surfaces, both sides. I also sprayed the rim with gasket tack spray before mounting the beads. It's held ever since, about four months now.
Brooksville
21 Challenger Super Stock
#79
Waxhaw
NC
#80
Update, tire spun on the rim at the drag strip today. Back to square one.
