- Member ID
- #1008
- Messages
- 692
- Reactions
- 1,180
- Likes
- 132
- City
- Mount Prospect
- State
- IL
- Country
- United States
- Vehicle
- 2016 Hellcat Charger
This "list" below is from my phone/laptop. I always keep a running list of what I've done or experienced with the car.....I'm not OCD, but organized They are my personal notes, and a great "pass along" if I ever decide to sell the car, which I have no plans on doing.
General:
Interior:
Exterior:
Performance:
- Supercharger replaced under warranty 3,000 miles. Bad bearings. Replaced with "AG" unit.
- Right rear shock replaced 9000 miles.
- Front rotors replaced at 5500 miles.
- E85 at 9200 miles
- Diff fluid changed at 12,450 miles (Amsoil 90w-120 with slip lock)
- Trunk lid rust area (fixed personally). Filed with FCA.
- Front bumper backed into at a gas station 3/27/18. No dents, but chipped paint. Re-painted portion. Re-wrap not to perfection.
- 3/1/19 noticed rattling from snout. Probably "play" in bushings from fixed metco pulley.
General:
- 2016 (May 2016 build) purchased private sale for $60,000 on 2/17/17. 1900 miles. Delivery 3/9/17.
- B5 Blue
- Red belts
- Harmon Kardon
- 2017 PK HR5 rims with 275 555 G2’s in front and 315 NTO5R DR’s in the rear.
- 2016 factory rims with blizzaks for winter.
- Forgestar D5 Beadlocks 17x10 305/45/17 ET Streets for racing.
- Block heater (hotter than factory) installed for ease of e70/e85 starting in cold weather.
Interior:
- All Led interior
- 2017+ RED SRT Airbag
- 2018 DEMON u-connect with 2017 + media hub for carplay and android auto
- 15% Tint on side 5% rear, 80% front windshield
- 2018 red dash plaque
- Color matched coolant tanks
- Billet Technology catch can, washer cover, hood strut covers, shock brace cover, dipstick cover, AC line covers.
- Color match strut tower brace.
- BLASTLED Red hellcat head door projectors front and rear.
Exterior:
- 2019 front grille pieces with new badge.
- American Bros color matched trunk hellcat badge.
- Redeye cat heads.
- Ceramic Coat, CQuartz where stripes were removed.
- Carbon fiber wrap on splitter, hood, spoiler (chip on splitter wrap)
- Blacked out side markers and rear tail lights.
- Carven 5” Black exhaust tips
- IKON rear diffuser
Performance:
- 180 t-stat
- Forced Inductions supercharger spacer plates with thermal blanket installed on belly of supercharger to reduce IAT.
- Killer Chiller with Drag Valve. Switch up, blue light on (cabin cool), switch down (drag valve) (12,500 miles). Gearhead fabrications 2 gallon auxiliary tank in front bumper crash bar.
- Cox 9lb Lithium battery (CTEK lithium charger if sitting for 3+ days)
- Tazer, double bypass, aux steering wheel buttons.
- Turboguard (track only)
- Carlyle racing Demon Springs
- Drive Shaft Shop 1400hp rear axles.
- Performance Development DIRS differential brace.
- Spohn Red rear trailing arms.
- Spohn Red Adjustable rear control arms for adjusting camber in the rear. Camber in rear set to -0.1
- Bwoody end links.
- Z26 brake pads all around.
- Livernois Driveshaft (6lbs lighter than stock @ 28lbs)
- 2017 dipstick (7.5qts w/full SRT filter)
- Magnetic oil drain plug
- Metco oil fill breather
- Injected Engineering Gasohol twin 450 "276" Walbro pumps (1000rwhp capable)
- Kenne Belle Dual plug and play boost a pumps. Boost reference adapter on supercharger lid for Hobbs switch which turns pumps on at 5psi.
- Metco 3" idler set (tensioner and below supercharger)
- Bwoody 3.0" idler for 2.4" upper
- 2.85 ring for 93.
- JBA Catless mids
- Injector Dynamics 1300s
- Brisk ER12S
- Barth Tune (PCM/TCM) -- only go WOT when trans is set to Track
- Diablo Trinity with Diablo PCM and 6 Tim Barth tunes (93 for 2.85 ring only, e70, e85, nitrous, and TCM for nitrous and blower only.
- 2 Ethanol test tubes for testing pump ethanol before every single fill.
- E85 for 80% on test tube and above. 21 degrees of peak timing.
- E70 for 79% on test tube and below. 14 degrees of peak timing.
- 93 WOT for 2.85 ring.
- 877rwhp/920rwtq STD on Drag Radials 2.4 upper setup on E80.
- 9.8@141 with a 1.49 60' on 305/45/17 ET Street R’s 2.5 setup 2018 season
- x.xx@xxx with a x.xx 60' on 305/45/17 ET Street R's 2.4 setup 2019 season
- Nitrous Outlet plate kit with 10lb bottle, bracket, purge kit, and warmer.
- NOS mini progressive controller.
- Nitrous Outlet center console buttons for arm, purge, and heat.
- Setup for 75 shot.
- x.xx@xxx with a x.xx 60' on Nitrous
- 8
- 1
- Show All
