BWoody or Spohn?
Good morning guys. Now that winter is here and the car is coming off the road, I'm finally getting enough cash together to do some rear suspension work done on my stock powered '15 Challenger HC. Eventually I intend on adding some power, maybe just a pulley and tune, nothing outrageous, but for now my plan is to get current power to the ground effectively. BMR Cradle Bushing is next in, but after that I would like to add adjustable components to make certain I'm getting a good contact patch. I'm neither an autocross or drag strip guy, I'm primarily looking to minimize the possibility of breaking the rear. Current mods include P4D 2nd generation of their original brace, Spohn non-adjustable Trailing Arms and Spohn sway bar end links. Ive read quite a few threads and am wondering if my needs will be satisfied by the Spohn adjustable upper control arms, front and rear, or maybe the BWoodys? After reading about noise, grease flinging, and the Spohns working themselves loose, I am a bit concerned. Idk anything about the BWoodys and if they have the same issue, and I would prefer not to have to spring for the AAD's as I believe they would be overkill for my application. The Spohn's are chrome moly with delryn bushings, and the BWoodys are 3/8" thick A36 steel with poly bushings. Thoughts please? Thanks as always.
