Direct Connection Stage 3
Ummm, anyone else see a lot of problems with this? Gotta be something fishy right?
https://www.dcperformance.com/p-redeye-stage-3-kit-dc170-77072557aa
  • Includes Redeye Stage 1 Kit and Stage 2 Kit contents plus: 1300cc injectors; high flow Demon fuel pump; e85 capable; ported and CNC machined cylinder heads; all gaskets (intake, exhaust, cylinder head, valve cover, spark plug); head studs; colder spark plugs; Hellephant snout; 2.72 supercharger pulley (to spin supercharger faster and create more boost); 10% overdrive harmonic balancer; and 2" primary headers. For 2019+ Challenger Redeye 6.2L vehicles. "
  • Install Time: 20 hours
  • Warranty: parts warranty: 24 months UNLIMITED miles, Vehicle warranty: 3 years or 36,000 miles, Powertrain warranty: 5 years or 60,000 miles
So I'm assuming the Demon fuel pump is the Demon 170 fuel system since Redeye already has the same fuel system as original Demon.
A 2.72 and 10% lower is way overspinning a 2.7 blower and will probably make 22psi?
E85 capable? More like mandatory.
Headers won't pass emissions in most places?
I thought stage 3 was gonna have a 3.0L blower?
Something's funny.
Mike Jesse
Bremerton
What a cluster "uc".
Doesn't say how much and injectors will be too small
Injectors may be OK? Mine maxed out at 62% back in March at the track. Only like 11ms pw. I wonder what fuel pumps the D170 has.
Injectors are to small. Dual pumps wont be enough. IDK what a high flow demon pump would be on a redeye
This package will make more power than a demon 170 with that pulley combo. Also doesn't this surpass their max cylinder pressure and that's why the 170 got a "built engine" This cannot be right. This is more pulley then when I went 8.88 at 155 mph
The 1300s are absolutely not enoguh injector in anything better than 1200 da
O high flow demon pump is most likely from the 170 i am curious what that is. Because no way they are going to do a triple return all 3 pumps on system
I dont think someone typed that out right. There is some explanation and language used that does not sound to me like "corporate approved" description. And i dont see.them putting 170 hardwaee in that kit, personally.
I do not see them doing more than a 3.17 and a lower to be honest.
I don't see them doing an upper and a lower period. Mine with just a 2.85 upper can't run on 93 anymore, I put it in 500hp mode when I'm running 93 with my flex tune to clean up the fuel system occasionally.
I'm thinking that the price will so extreme that no one will buy it anyway.
Link is now saying.no longer available for purchase, at.least when i click on it.
I'll take two!
No way 1300 are fine
Apparently it comes with head studs??
probably going to be a $15k kit with install
So you’re telling me I shouldn’t run a 10% lower with my 2.69 upper? 😅
A 2.4 is different. But that’s still pushing it
Yeah, I know the 2.7s have a lower rotor rpm threshold. Interesting DC would offer this. I’m sure it’s for off road, has to be.
