Enclosed car hauler help.
I have a enclosed car hauler but I cannot open the car doors to get in and out. The wheel wells are too high. Has anyone modified there hauler to raise the car up over the wheel wells?
Thread Starter #2
Like 6 inches
I was thinking of using some ramps but wanted to see what others have come up with.
srtdusty
Indian Mound
2016 Challenger
boards with the ends cut at a angle.
Plasticman
Opelika
AL
2016 Charger HC
Most people I know crawl in/out their side windows when hauling cars.
Rob
Rob
I weigh 300lbs that's not happening.
572 savoy
Winona
2018 Demon
Do you have a smaller friend or family member? If they can drive have them either go out the window or crawl out through the trunk with rear seat down. The kind of trailer that allows doors to be opened are either ramp over or escape door types. Both are not cheap. The other option is to use a winch and pull the car into the trailer once it's on the rear ramp.
Good luck.
Good luck.
I am planning on putting in a escape door but still need to raise the car to clear the well.
572 savoy
Winona
2018 Demon
Other problem you may encounter is the approach angle with a raised platform which clears the wheel wells. I do know some open trailers have removable fenders but no such luck with enclosed.
Octanewide
House of power
I personally would not raise my car that high in fear something might shift or slide when your towing it and damage the car..
I am going to take a few more measurements tonight. I thought cutting out and adding the escape door was going to be the hard part.
2x12’s
Simple, cheap, perfect rise.
Use a winch. I have a 13,000 lb rated with a nylon cable that is very easy to use. It has a wireless remote that I can use while I walk along side the car with one hand inside on the wheel to keep it centered. No need to ever crawl into the car and that thing will drag that car in there with the wheels locked. You can get a big one like mine for less than $400. 54829732-CE3E-47C8-93E7-8D61F452D4C4.jpeg A1932C02-0630-477D-85AD-31C766B1F21D.jpeg 516C0649-93EC-4858-81B4-6DA22A7EE977.jpeg
Did yours come with the escape door or did you put it in?
United Trailer
Came with/ordered it like that...
Demon1
Naples
2018 Dodge Demon
Thread Starter #20
Going to have to add in my own escape door and make those ramp overs. Thanks for your help guys.
