Oil Consumption.
gldwing57
WV
I had to add a quart of oil after only 500 miles is that normal? Its got 800 on it now and I haven't checked it yet Im hoping its just a break in thing.
HellcatMike
Yes it happened to me as well. Should be fine after that. I would still keep an eye on it just in case.
RonHellcat
Mine was a little low but not 1 quart.
John G.
Spokane
Per the owner's manual, that is normal.
G
gldwing57
WV
Thanks for replies guys.. I will keep an eye on it. I noticed something else on mine. When its cold and you 1st start it when you stand outside seems like there is an exhaust leak up near left side of engine but after it runs just a minute or so it goes away. Have any of you ever noticed this?
John G.
Spokane
No, not on mine. If it sounds like an exhaust leak, it probably is. Since it goes away after a minute, I would guess the heat causes expansion and seals the leak.
LonestarHellcat
Does not happen on mine.
Weiseguy707
Glen Ellen
2019 Dodge Challenger SRT Hellcat
I had to add a quart at about 500 miles and again at 1000 miles? I’ve also noticed some upper valvetrain clatter at startup momentarily but nonetheless doesn’t seem right. Going to do an oil analysis to see if anything abnormal shows up.
