Spark plugs for a slightly modded cat
Koozies fat cat
The villages
2015 hellcat charger
Hey all. I have a 2015 with the ripatuned lower pulley and an intake. Do I need to replace the spark plugs with stock gapped plugs or something more gapped since the car isn’t fully stock?
Probably not, but if you want to check them and change them while there most use NGK 2309 gapped at .028” for mild boost applications.
I ran stock plugs in mine at 20psi with no problems, but when it's time to change them do what GoManGo says.
I just replaced mine gapped at .021 😎
I’ve run 30 psi of boost on the NGK 2309 gapped at .018” with the 3.8 Whipple, they are still in the engine at that gap at 24-25 psi of boost now with the 2.7 IHI, runs good enough to break my Tranzilla lol.
With more boost less gap not more is better, especially on a wetter aircharge charge with ethanol.
.018 is pretty tight lol, I just didn’t want spark blow out and I know I’m making more boost now and it breaths better
Last set was .028 and they got a bit wider and was starting to break up under boost
K
Koozies fat cat
The villages
I’m barely pushing 13-14 pounds of boost with my setup as is. I guess stock plugs isn’t an issue.
@Koozies fat cat
What lower pully do you have?
Or are you running the RipTuned "Incognito"
K
Koozies fat cat
The villages
Same setup (tuned) I've been running since 21 on stock plugs. No issues so far.
K
Koozies fat cat
The villages
Did you leave the plugs at the 0.032 stock gap?
K
Koozies fat cat
The villages
Change them. Do .028
I have 59k miles and have changed the plugs 3 times, and have closed to gap more each time. I’m now at .021. NGK 2309
Latest Forum Posts
