Transmission mod
I be think people sell a lot of stuff that just isn’t necessary for the cars , like tuners that over sell saying it will make it faster when you can go fast without all the bells and whistles
I’ve seen them fail on the Ram trucks you speak of but on the hellcats I haven’t had one with the issue
Brian Carter’s car had tried to eliminate it and he ran into a converter charge issue and the car would not shift 1-2 under full throttle at the track , he went in a ghost chase trying to figure out what the issue was and finally he reinstalled it and the car went to shifting again,I believe his is a 19 model maybe the later models are different as I know earlier models from people that have removed them haven’t had that issue, me personally I’m ok with it being in the vehicle because I’ve never had an issue and the trans has broken 4 e drums but has never showed an issue with over temps
I haven't paid much attention to the trans temps at the track or the hwy so what do the temps normally get to ?... and is turning down the setting in the tune help or worth doing like @Hpindy has done ?
Thread Starter #23
It's actually the fan settings I change but in the transmission part of it .
Mike L.
Yorba Linda
'16 Challenger Hellcat A8
I have not played with this on a Hellcat as I don't do car transmissions. I have seen Ram trucks with bypass problems. I don't understand why it could possibly affect shifting on a Hellcat, but I will find out. Since the bypass is sealed, I just ordered one from Revmax and will install it on my kat. I'll also look into what it might affect in the trans.
WhipCat
In the Jungle
My local shop dropped hellraiser trans because to many inconsistent issues. The last 3-4 cars that had trans put in all had to get pulled again and fixed. Just what I heard.
OK, my fans have been turned down also, but not sure if it's been done on the trans side of tune (by my tuner) ?....my idling coolant temp hits 190* > 192* & fans are on high & it comes down to 185* with 180* t-stat.
Thread Starter #27
I"m away for work but when I get home I will look at my laptop and post a pic
8HPXTREME TRACK TESTED in an 8second car 😁
WhipCat
In the Jungle
daaaang let’s go! That things got the sauce
Fayette County
Hellno is the way to go! Dave is a true domain expert.
Thread Starter #31
I agree with this . He testes his stuff to the max in the real world .
^^testes????? ROFLMAO
Thread Starter #34
Haha this is why you don't text and drive at the same time !. I'm going to leave as is because of my stupidity.
WhipCat
In the Jungle
@Hpindy he’s talking to me too much and my redneck has rubbed off 🤣😂
you want to build one for me?
cole3986
Lawrenceville
Is the E drum problem resolved? Never had a problem but brother Hellno has gone thru some, what is the issue, is there a post on it?
I have the billet steel drum now and it’s done well but the drum breakage is not because of the trans it’s the driveshaft being shoved up against the flange of the transmission and causing a bind up which then breaks the drum
Dman007
7 Second Best E/T
Smyrna
2019 Charger Hellcat
@Mean Cat Dave has not been doing anything but sitting at home and wishing he could go racing. LOL!!
all jokes aside, we have raced 35 weekends this year. I would say that is kind of busy.
@hellno update your signature block you lazy sob LOL!! 9.20 best ET :ROFLMAO::LOL::cool: slow-bee
Thread Starter #40
One piece driveshafts with no slip joint ??
