I'm assuming you got the blower back? I really like their blower plate and cast snout. Would be the best flowing out there
Thread Starter #162
I've been traveling and asked SDG to hold it till I got back. Will be here tomorrow.
Traveling? You’ve got videos to make. Inquiring minds wanna know😂😂
Mrs Speedy dragged him away from cars to take her on vacation:p
Thread Starter #165
It's funny I'll tease her and say "my people are waiting to hear from me" :ROFLMAO: and she just rolls her eyes
She’s just jealous😂
Thread Starter #168
Couple sneak peek pics Jesse sent me. Blower got here last week, but I've not opened it yet. Been working with the cradle lockouts.
Coating is proprietary on these new rotors. Jesse described it as having an increased lubricity vs factory and is intended to help them run cooler. Blue is SDG's color, so...
Staked bearings.
Gears setup.
Staked bearings.
Gears setup.
their pink oil is faster then the green:unsure:
wow, doesn't look like a whole lot of oil volume in there relative to where the fill port is, unless the photo is being deceptive?
Thread Starter #171
SDG informed me the lower plug on the back is actually the fill plug. The upper plug was used in the assembly line and houses an additional magnet. I'm guessing the gears act like a paddle wheel on the lubricant.
Ah, very interesting. Thanks Speedy!
6oz is the fill amount. Look at the bolt in the smaller left gear. See the funnel shaped taper in the center? That leads to a small hole drilled through the bolt which leads to hollow shaft in that rotor which leads to a side drilled port in the rotor shaft that comes out between 2 seals behind those bearings. That area leads to those breather ports under the blower. The gear spinning at 20-30,000 RPM’s centrifugally separates the oil from the air so no oil escapes unless the blower in tilted to far towards the rear and oil gets in the hole and then comes out those breathers. There’s also another port that is behind the pressure seal that returns any list pressure back to the suction side of the rotors to recirculate it. Allot going on behind that curtain.
Looks like a job done right! 👍👍
Yes, a ton of engineering in there for sure, and you lucky guys who have had a chance at dissecting the hardware sharing all this with us who have not (yet?) is greatly appreciated!
Thread Starter #175
For all the engineering they shoulda done a little something better on the gear set side IMO, but then again they were designing for a stock system.
Thread Starter #176
Bringing this back to life. Planning on re-assembly tomorrow. @16GoManGoHC2 you suggested I use SS button head bolts instead of the plastic push pins on the FI spacers? Do you remember size and thread pitch? I think that's the only thing I don't have sourced.
Was just thinking the other day that there had not been an update on this SC in a while ;)
He didn't want to lay the smack down at Moparty so he is putting it on now:)
Thread Starter #179
If I had known in advance we could run faster than 10.00....maybe :LOL:
Thread Starter #180
Anyone have access to the torque specs for these T30 water manifold screws? Looking at T30 screws the max torque is 31.1 - 37.4 Nm (23 to 25 ft/lbs) which feels way too much.
