'Chute
22RENBS2 & 170
Anyone put a 'chute on a Challenger? Looking for the best low budget parts, how-to and where to get.
Carlin Fabrication sells a complete do it yourself package. image000000.jpeg IMG_7870.jpeg IMG_8019.jpeg IMG_8066.jpeg
Bowlerguy92
Oh boy. Here we go.
Now we all know 2nd Amend is cheap....(he says so himself)...I can see the Army surplus chute zip tied to a trailer hitch already...:oops::oops::rolleyes::rolleyes::rolleyes::giggle::giggle:;)
22RENBS2 & 170
I like that idea!!! I can pinch it in the trunk and pop it when I pass the finish line!!!!
22RENBS2 & 170
You think the purple monster doesn't need one? Only if you don't go! ;)
Now yer talkin....
Jon-MooredPerformanceLLC
Martin
2018 Dodge Challenger Hellcat
Martin
If you do a bolt together kit that you buy from motion you will most likely have to go right through the middle of the plate and you are mounting to the stock bumper. This you have to trim the bottom of the plate put you can 100 percent leave the plate in tact and just cover the hole with a license plate cover frame.
22RENBS2 & 170
Thanks Jon.
I hope to not remove the rear fascia, it is almost impossible without breaking the tabs.
22RENBS2 & 170
This is looking like too big of a project to do in one month (for me) so I plan to go chuteless and beg for an exception in Sept. My excuse will be that my speed limiter caps me at 204. I'll take the winter to plan it all out and get it right. (And cheap!!!) It will also give me a chance to look at what the really fast guys have and understand better.
Please keep the suggestions coming, I greatly appreciate the help.
Back when I had the single chute done, it was simply bolted to the crash bumper using a plate with four bolts. At the time the shop that did it (SpeedTech) told me that a Chromoly tubing replacement for that bumper would not be any stronger than the extruded aluminum bar. Lighter but not stronger. I have deleted most of those old pictures but I do have one that shows where the chute attachment bar comes out thru the cover under the plate with that setup. I deployed at over 180 mph on a half mile no issues. IMG_8041.jpeg IMG_9980.jpeg IMG_8893.jpeg
Back when I had the single chute done, it was simply bolted to the crash bumper using a plate with four bolts. At the time the shop that did it (SpeedTech) told me that a Chromoly tubing replacement for that bumper would not be any stronger than the extruded aluminum bar. Lighter but not stronger. I have deleted most of those old pictures but I do have one that shows where the chute attachment bar comes out thru the cover under the plate with that setup. I deployed at over 180 mph on a half mile no issues. View attachment 170620 View attachment 170623 View attachment 170624
just curious...how beneficial is a chute @ 180...is it just to save on brakes
It’s all about saving the brakes. If you’re running something that requires a chute to keep you from running off into the weeds (or a safety net 😳) You need more brakes.
(y)
Jason at Carlin Fab makes a kit as well. I've been running it for 3 seasons.
Latest Forum Posts
