Adding trailer package???
Don’t mind @Jimmy N., his brain is still thawing (not quite defrosted in the arctic yet) and doesn’t realize everyone doesn’t use multiple vehicle/heavy equipment hauler goosenecks that probably weight over 5k lbs lol. A lot of people tow their hellcats to the track with an r/t with tow n go. Tow away with your Durango! But the TRX is probably the better rig. If you really want to tow, you should trade them both in, get a 2500 super duty and a gooseneck 😉
Braaaaap
Braaaaap
Active Military
Law Enforcement
2021 Durango Hellcat
Thread Starter #22
Haha no offense taken.
Its the equivalent of someone asking for a simple home defense shotgun and being told unless you have claymores, a MK19 and M2 don’t bother with it 😂🤣
72 440 Barracuda
Graham
For towing it's hard to beat the one ton dually long bed with the Cummins. I have many miles towing with mine and I find wheelbase helps and the dual rear wheels eliminate almost any unwanted trailer movement. Compare that to towing with a 1500 short wheelbase and they are worlds apart.
Most people in here are talking about using normal trailers for 1 car, not multi vehicle/heavy equipment haulers lol. And you put 195 tires in your trx? 🤨
Well, the trailer I use the most is a little 18-footer, almost long enough for most cars (I might add two feet to it). But it's too narrow for a TRX, for example.
And yes, since the OE tires are the widest allowable for the 9" wide wheels, they didn't exactly provide crisp handling - something the TRX already isn't very good at.
A rear anti sway bar helped quite a bit, especially with the squirrelly behavior when accelerating to pass a vehicle. Most likely the AWD being a little upset when the right rear corner drops due to the squishy suspension.
Going to 295s really helped stabilize things, and as an added bonus is much better in slush. And in snow and on ice in general.
WTF Holy guy....Jimmie lives in the South West...not in the Artic Circle :rolleyes: (I know yer brain is half baked from the Fla. sun...but you really gotta start payin attention):oops::oops::oops:;)
Well, if all I towed was 10K I might consider a 2500. Gasser.
A lot of people feel that a 1500 is more than enough for towing, but I am not one of them. Having towed from 1,5K to 65K I have developed a feel for what works well in real life (not J2807 ratings).
Again, 3K behind a TRX, okay, but it still wouldn't be my first choice. But better than a Durango, because of the extra weight and wheelbase.
So I can't use my 4 door for towing, it has over 900 lb/ft of torque:unsure:
That would make it score well in the J2807 tests.
They really like power (to go up hills), but aren't all that concerned with going down hills, stopping, handling, or longevity.
High tow ratings sells vehicles, and the J2807 crew seems happy to provide them.
I forgot how cold the desert gets
My 2021 Jeep GC 5.7 has a 7,200 lb towing capacity. I towed a 6x12 U-Haul trailer with tandem axles both with this one and my previous V-6 JGC 800 miles down I-95. It was effortless. Even though it would be ok weight wise, I wouldn’t want to tow an 18’ open trailer with a car on it. The short JGC wheelbase would not be good for that. All he’s towing is a small trailer with a ATV or one or two motorcycles. That should be no problem for a Durango or a Ram 1500.
I wouldn't tow with a 1500, but is has to be better than doing it with a Durango.
Only certain swamp people and DGatzby do that.
I guess I am swamp peoples.
Luthersville
2024 Dodge Durango SRT 392
I was under the impression that all DHC’s came with the hitch and pin setup. I was mistaken and ours does not have it 😂.
What is the best way to get this done? We have an open utility trailer we use for dirt bikes. Our trailer does have brakes on it so a trailer brake controller would be welcome as well. I see plenty of “kits” online just didn’t know if someone has first hand experience with any of them.
Order the hitch and wiring from the dealer. The factory Trailer Brake Controller is no longer available. Go with the Prodigy P3 TBC - PART # 783192015686— and check with the folks at etrailer.com to see if you need anything else. That should be it though.
Wraith_2018
Arcanum
2018 Dodge Durango SRT
I have a 2018 DD SRT ordered with no spare or tow package. Found the Hitch assy at a local LKQ for $75.00 Ordered a new harness from Moparpartsoverstocked online, was $199.00
The bolts and rivets needed I found at my local dodge dealer. I put everything in except the wire harness: I had dodge do that as it required a PCM (system update) I was in for $1000.00 dollars when it was all complete. Works great, all oem parts
CPO Super stock
westminster
2021 Superstock
well crap last 5 years i have been doing it wrong but it works. My 1500 Etorque has had zero issues towing a 2K trailer and a 4500 car.
The factory option with the Class IV system in 2018 was $995. Good job.
