28 X 6 Sportsman S/R Radial Front Runners
Rollieman
Hamilton
MA
Apparently, these front runners are very capable on the street with their 8-ply rated radial construction.
They have a load rating is 1,650 @ 95 PSI.
Can you recommend a general range of PSI for the street and strip?
Thank you !
They have a load rating is 1,850 @ 95 PSI.
Thank you !
95 psi to get the full load rating
Thank you !
1650...
Correct, the only rating to run these at due to the weight of the cars.
TNREDEYE
Shelbyville
I use these on my SS. They work great.
Btw, they're literally a truck tire. LT rating.
I run mine at 95psi as recommended.
That’s the reason why I took so much weight out of the car, I run the et street fronts and the load rating is like 1480 at 50 psi, so I’m over the load rating
Whoa nvm, it’s 1140 max load 😳
It's why I got rid of them. Run the hoosier bias ply up front.
Hopefully mine don’t blow out
BoostedGTA
Greenville
SC
Do you run the Hoosier 28x4.5x18? I can't seem to find what pressure these should be run at...
There is no advertised pressure, I run 50psi but Id never run them on the street.
