8HP95 Durability
TheGasMan
Military Veteran
Austin
TRX
Does anyone know how durable these transmissions and torque converters with respect to low RPM torque? Is it already at its power limit from the factory?
Demonic Cat
Mid
RI
@hellno is best suited to answer the durability of stock trans, and what will be best for upgrades of it if needed.
This isn’t a GM Ford or GTR you’re good to go
One of the best automatic transmissions ever made
Jon-MooredPerformanceLLC
Martin
2018 Dodge Challenger Hellcat
A good trans tune they will live a long time. A bad trans tune they burn up quick
Hatermkr
West bend
2016 helldemon
Best trans tuner I’d Barth tuning 😂
WE KNOW THSES TRANSMISSIONS CAN HOLD OVER A 1000 LBS TORQUE BUT THERE ARE OTHER FACTORS IN PLAY ,TUNING OF COURSE !!! AND THEN OTHER PARTS START FAILING AS WELL ,,THE WEIGHT OF THAT TRUCK SURELY DOESNT HELP AT ALL
T
TheGasMan
Military Veteran
Austin
TRX
Assuming traction is optimal, how does this trans and torque converter hold up to low RPM torque and rolling WOT downshifts wih this power?
ROLLING AT WHAT SPEED I CAN SAY THAT ROLLING IN 8TH AND DO A FULL THROTTLE DOWNSHIFT ,WE SEE A LOT OF INPUT SHAFTS BROKEN FROM THAT BUT, SAY 40 ROLL ID SUSPECT IT WOULD BE FINE
T
TheGasMan
Military Veteran
Austin
TRX
I heard from a respected person inside the mopar racing community, that one of the limitations of this transmission is tuning, with respect to WOT-downshifting. Is this true?
Martin
Almost sounds like you blew a trans and are wondering if that is normal. Is this the case?
When you say limitations do you mean knowledge of or its not possible?
WOT downshifting with these cars is a dumbass thing to do. No good reason to do that.
^^^ No good reason for any trans IMO
T
TheGasMan
Military Veteran
Austin
TRX
“Almost sounds like you blew a trans and are wondering if that is normal. Is this the case?”
Me personally, No.
“When you say limitations do you mean knowledge of or its not possible?”
I am not an engineer nor a tuner, and I have very little experience with this topic. I was told that the Achilles heel of this vehicle’s transmission was downshifting at WOT when the vehicle’s already in motion, and tuning limitations is the reason why. I haven’t found any documentation regarding this topic. My questions are to learn and avoid costly drivetrain repairs.
Me personally, No.
DRIVE IT LIKE A LITTLE OLD LADY NO DRIVETRAIN ISSUES :LOL:
