Brake rotor teaser thread
Blkout
Warner Robins
There is a new rotor type and design coming out for the Hellcats/390mm rotors that will take light weight to a new level.
Where is this info coming from?
Blkout
Blkout
Warner Robins
Not many yet, and I shouldn't hi-jack this thread
Hey bull
Will your source be making rotors in the 360mm size( demon front rotors) ? I am waiting patiently but until then I'm happy with my current set up
Ok, moved some posts to a new thread
Hey bull
Likely, although probably not with the initial announcement.
Demand will certainly drive follow-on fitments.
@Blkout
@Hpindy
'Not sure if you got tagged when the new thread was created.
Blkout
Blkout
Warner Robins
Alright, lets continue with more details, links, inside information.
@BULL
I'm here now . I know we talked before about these new rotors but it's been awhile. I'm not going to pry but I will be waiting patiently. I am one of those guys that thinks "out side the box" and all these "little" thing add up eventually and that's what I like .
33-40%
My front rotor set up.
Weight?
Rotors 19 lbs
Calipers 10 lbs
Stock hellcat stuff
Rotors 34 lbs
Calipers 16 lbs
@Blkout
@Hpindy
*as with any unreleased design, specs not only subject to change, but likely will, in either direction... For example, an early design was even lighter, but didn't pass Patent scrutiny
Currently:
~1/3 mass of O.E. (390mm reference)
~1/2 wear of O.E.
Equal or better heat capacity than CF
Less expensive than CF
More durable than CF
Patented/proprietary MMC alloy
Here's another exciting piece:
Two teams have been selected for Beta testing, ~two more are being sought after. Selection will be based on many factors. Rotors will have to be returned for eval.
@Blkout
@Hpindy
Currently:
~1/2 wear of O.E.
Excellent. Sounds interesting. Looking forward to the results .
If it is publicly patented info, what's the aggregate in the MMC?
If not public, then I'm not even asking.
Too soon... Just from a strategic standpoint
(How well do you know your relavent alloy mass ratios?)
Interesting
2fast4u
Edwardsburg
Following...
