Cutting 1.1x 60's
zhc
2016 Dodge Charger Hellcat
Originally posted to show a race versus someone I thought I raced but turned out to be someone else, one of my clients actually from California in his Demon. So I'm changing the purpose of this thread to show some vids of me cutting 1.1x 60's and maybe share some info on how I do it.
So here, I'm testing a small shot of nitrous, 150 shot with the 3.8L Whipple getting data so that I don't do a crazy wheelie later when I decide to turn it up.
Having a lot of power to work with helps, at least it helps me a lot. Tire, suspension, and radial track prep are the other critical pieces that you must have.
I use MT ET Street Pro 315's for my tire, BMR suspension rear arms, their solid bushings, and Menscer coilovers through Reed Motorsports.
If you pick BMR, their single off car adjustable arms are stronger than their on car adjustable variants and ever since I switched, I haven't had any issues.
The other brand for rear suspension parts, AAD, is good too and very popular but they weren't around much when I got started and what I have works for me so I never had a good reason to make a change.
More vids to come, of 1.18, 1.17, and 1.16 60's will be posted later.
I think @Hatermkr had a bigger wheelie but think you got him on the top end lol
TNREDEYE
Shelbyville
Z - I watched your car a few times in Houston. The first 3-4-5 feet your car covers is amazing. It's crazy smooth. No jerking, yanking, shaking. No effort to do some giant wheelie. Very impressive.
Z
zhc
Yea it doesn’t take much to go into a massive wheelie with how my car is setup.
There was a viral tik tok of me doing this not too long ago. This was a blower only pass attempt.
https://www.tiktok.com/@basty436yt/video/7176814596869639450
Hatermkr
West bend
2016 helldemon
@Hatermkr At the time, I had no idea that was you in the other lane.
Who "won"?
That was not me lol
Z
zhc
Oh, haha…. Well darn.
Z
zhc
I updated my original post, will see if it catches any attention.
Z
zhc
And here's a vid and slip of a 1.173 60', this was on a smaller 125 shot. Although I had less power, how you manage that power is also key. With some tweaks to the tune and how the nitrous ramps in, I was able to improve my 60' from earlier while going into a small power wheelie in the process. At this point it's a delicate balance, if I'm not careful and get over zealous, the car will absolutely stand up on it's back bumper.
1.1 60’?! That’s insane!! I have to get out of the 1.5s… thinking I have to swap out my 3.70 for a 3.09 soon and waiting for better weather. Putting in the work Z! That’s amazing
Hatermkr
West bend
2016 helldemon
I see shocks helping this. Not doing this on factory stuff
Z
zhc
I think a 3.09 would be a better fit. Interestingly, if you were to launch in 2nd gear, it would almost be like launching in 1st gear with a 2.62. Specifically it would be as if you were launching in 1st gear with a 2.47. You probably don't have enough power to make that low of a ratio work in your favor though, probably not even worth trying.
I just want consistent 1.3x, the issue is I keep breaking drivetrain. Here is my suspension setup.
Full AAD setup, I mean everything.
BMR Cradle Lockout
BMR Diff Lockout
HHP Springs
Sport selected in the Uconnect
Diablo Suspension Controller
Leave off idle.
315/60r15 ET Street Radial Pro
P4D Dirs
I know prep is very track dependent so I will try and not add that to the equation. But MIR and Cecil are some of the quickest on the east coast. Capitol... well they are slowly regaining their land of hook status, last week the track was tight, ask me how I know...
Z
zhc
BMR Cradle Lockout
BMR Diff Lockout
HHP Springs
Leave off idle.
P4D Dirs
I'm having trouble remembering, do you have an aftermarket converter? That plays a part too. I find that chasing the hit (as in trying to put more power into the hit as the track will take) can be extremely hard on your drivetrain. Also, wheel hop or sudden torque changes can weaken or break parts. Here's an example of a sudden torque change. You launch, it hooks for a moment but then spins so you pedal and immediately get back on it. Doing this sequence has lead to one immediate break for me last year and possibly contributed to breaks within the next 1-3 passes. An input shaft (trans), a planetary gear set (trans), and a driveshaft last year.
Hmm, that is interesting. Yeah, definitely not making enough power
Z
zhc
@fumanchu182 I don't have diff lockouts, always thought that too much stiffness there would put more stress on the diff's case versus allowing the bushings to absorb some of that energy.
@fumanchu182 I don't have diff lockouts, always thought that too much stiffness there would put more load on the diff's case versus allowing the bushings to absorb some of that energy.
3000 stall from pure
I have never left at 3k willingly, I'm thinking of using the launch control or installing a two step to limit it to 2k
Personally, if I went that route, I’d use the stage6 so that traction control isn’t turned back on
Tool Time
Tampa
That's a great looking run. Quick and fast cars generally aren't wasting motion/energy on wheelies. They hook and go. Like yours does
Z
zhc
The Menscer coilovers helped a ton, front and rear. However if you get coilovers for the rear, the wheel has to be spaced out quite a bit to not rub.
Z
zhc
What does your converter flash to after you go WOT?
