hell on wheels
Saint Paul
Dodge SRT Demon
D170 should be good
for a claimed
20 minutes
Of heavy track use.
Thread Starter #1,164
Gotta be a random assembly issue. Several have dozens if not over 100 passes. Or running fuel like E90.
Hundreds of passes sounds like a lot
Thread Starter #1,166
Look at Demonology. That guy races 4 nights a week!
Under-Pressure
Space Coast
Stellantis 2dr
Any details available on mods or tune?
Thread Starter #1,168
That's a good question. I've been assuming it was stock but perhaps not. If not an even bigger question on why he posted it on FB.
If that was my full time job I would too
Views?
Thread Starter #1,171
Is that a thing on FB? Serious question I have no idea.
I’m pretty sure there’s still add revenue there. And if not it’s just another segment to reach people not on other platforms
exactly. Only that Nellis is an Air Force base that's not located in Volusia County.
Some good memories made at Nellis AFB.
I have confirmed this he has multiple cases in FL.
DUI - reduced to wreckless driving: 2023 304656 MMDB
PLEA deals:
Nolo Contendere to POSSESSION OF FIREARM BY CONVICTED FELON (2F) - 2023 303535CFDB
Nolo Contendere to BATTERY ON LICENSED SECURITY OFFICER (3F) - 2023 303651 CFDB
Nolo Contendere to DRIVING UNDER THE INFLUENCE (1M) - 2023 304656MMDB
Hiding from Probation on a military base???
Dear Honorable Judge Kathryn Weston
On 04/11/2024, this officer filed a violation of probation report regarding the defendant absconding from supervision.
The violation report was done based on information provided by probation and parole in Nevada through the
interstate compact. It was reported that the offender was unable to be contacted and that the offender was not residing
at the address he provided to Nevada probation and parole. In addition to this, probation and parole officers were
denied entrance to Nellis Air Force Base where the offender resides. The defendant has since made contact with this
officer and is no longer an absconder at this time. It was also determined that the offender is currently in a medical
treatment program for a terminal illness and this officer believes a mail/phone reporting program would be more
beneficial for the offender to successfully complete his probation at this time. Attached for your convenience is an
order dismissing the affidavit for each of the defendant's cases.
4/15 they have rescinded the affidavit. Therefore he is no longer in violation of Probation. I shall not cast judgement, just putting out what is in the public record. HIs videos are still funny and entertaining.
I hope he gets help if he wishes for it or needs it. Maybe lay off the sauce for a while.
It's crap revenue compared to commietube and fakestagram.
Under-Pressure
Space Coast
Stellantis 2dr
Well said & Amen to that. Treatment for terminal illness was stated above & prayers headed his way.
Who are we talking about
PLEA deals:
COLUMBUS
KS
MANGO D170
E90 is a total NoNo. I was running VP C85 straight out of the can in Dallas at something like -500 to -800 Da and I had no issues with the car cutting power. Car said E80 to E81.
But the car is supposed to cut power if it is lean or out of injector. Says so right in the owners manual if someone decides to read it.
I did have one problem. It did shut off in the middle of a 3' Wheelie once. I am thinking it grabbed the wrong shift table and hit the Rev Limiter but no way of knowing for sure. Did some damage underneath and took the wind out of my Sails. I was still able to get an 8.8999 and a 8.9000 managing the wheelie with the throttle. A very interisting Day to say the least and well worth the one G for fuel...........I was able to get the 8.896 just saying F-it. But I really did not want a repeat.....
Thread Starter #1,178
I was quite a bit less than E85 fuel mix and in +600 DA mine hit 83% injector duty cycle in my logs. Fuel pump duty cycle was 89% (maxed). I'm afraid to try full E85. E90 would have to be a hard NO unless larger injectors at a minimum were installed which would also require a tune.
I've driven mine on the street quite a bit with several romps now. I've not had any shift problems. Wonder if it's learned which tables to use based on my driving.....I'll have to keep an eye on that.
Wonder if this car that blew up was actually tuned? Owner didn't say it was.
If it was tuned i think it would be less likely blowing up cause you would upgrade injectors. It sounds like they need bigger injectors or run more on race gas then e85
Thread Starter #1,180
Not if it was over tuned, ie too much timing for the engine and thus E90 fuel being used :unsure:
No reason to need any race gas at all in this car.
