I think it takes some time for your car to pop up too
So I'd contact them.
Shouldn't go live before the 15th
yea, trying BAT can't hurt - quite active and you may catch your buyer there. Only thing - be ready for all the fanboys and internet experts to slather themselves all over your ad. That's my big annoyance with BAT - it's a playground for wannabees that muck up serious buyer Q&A
Illegal_Demon
Open Space
130K with Crate Deliverd anywhere in the lower 48.
Ebay= non-serious tire kickers/time wasters
Put it on BaT if you want it to sell.
few demons in there all sold for $140k+
VICTORVILLE
MANGO D170
Thread Starter #665
Just curious if You all think I am going to kill myself? One of my pet peeves if the lack of the ability to put a TPMS sensor in the Billet Specialties Win Lite Skinnies. So.............
Screw is an allen head machine 10-24X ¾” (not the one in the pic) and the sensor is about 2/3 the size of the older ones. Hole is blind. Sensor is clocked 180 deg from the Valve Stem to attempt a more nuetral balance. These are for 22 model year and newer, because..................
. TPMS WIN LITE 1.jpg TPMS WIN LITE.jpg TPMS WIN LITE 3.jpg TPMS WIN LITE 2.jpg
Screw is an allen head machine 10-24X ¾” (not the one in the pic) and the sensor is about 2/3 the size of the older ones. Hole is blind. Sensor is clocked 180 deg from the Valve Stam to attempt a more nuetral balance. These are for 22 model year and newer, because..................
. View attachment 105986 View attachment 105987 View attachment 105988 View attachment 105989
Ehhhhhh lol
TNREDEYE
Shelbyville
Looks like a good idea to me. Don't forget the loctite.
VICTORVILLE
MANGO D170
Thread Starter #668
Loctited the screw threads, under the head/washer and I ran a bead of silicone on the back edge opposite the mounting screw to dampen vibration. I REALLY like having TPMS even at the race track.
FYI, Loctite WILL attack engineering plastics and cause them to fail.
Easy answer is to keep the Loctite on metal threads only.
You also removed your rear swaybar so idk about that lol
hell on wheels
Saint Paul
Dodge SRT Demon
I ordered a new tpms.
it reads all the way up to 60 psi.
For my front tires.
For my front tires.
It glows. View attachment 106011
I think that’s what my expensive harbor freight digital one goes up to, it’s really nice. And it’s accurate
@Diboblo has the instructions on how to disable tpms if you run drag wheels, that’s what I’d do. I don’t have tpms sensors in my drag setup, just billet specialties valve stems
I also run the light ET street front which have a max cold PSI of 50, a bit over weight, but I stripped a lot of weight out of the car. They’re fine rolling down the track
hell on wheels
Saint Paul
Dodge SRT Demon
I use the race master front runner.
my other intercomp tpms only went to 30 psi.
I want to be able to fine tune my roll out.
I’m going .00 on the lights
this season.
You’re typically always running 50 psi+ to meet the load rating on the front tire, and you can’t adjust the factory tpms system up that high so it’ll give you a warning, so imo tpms on the front are pointless anyway. @16GoManGoHC2 is a machinist/engineer, maybe he can weigh in on the saftey of the tap you did. It’ll probably be fine
VICTORVILLE
MANGO D170
Thread Starter #677
I am glad you like the ET Street front. One person I saw posted he did not like them and took them off. I kind of wonder if he had some other problem with the car.
I am going to have 2 setups for the new car and one of them is the Street legal ET Street Front paired with the 315/50R17 ET Street R. That is going to be my every day setup.
To set records I am going with the Hoosier Race Tires. The 4.5X28.0-18 race front paired with the 10.5X29.5R17 DBR rear. I sincerely hope I can get the car to hook on that Hoosier DBR. With 1025 HP it might be difficult. But I will use the on board software to soften the HIT if necessary. Also, I will be on MAX PREP when I run that tire, of course.
That’s the setup I run in my car and it works great, 15 passes or so and the et street fronts are great, car goes straight and smooth. Did you get an allocation???
Sounds like he did.
Or he is waiting for the dealer stock cars to show up.
To set records I am going with the Hoosier Race Tires. The 4.5X28.0-18 race front paired with the 10.5X29.5R17 DBR rear. I sincerely hope I can get the car to hook on t5hat Hoosier DBR. With 1025 HP it might be difficult. But I will use the on board software to soften the HIT if necessary. Also, I will be on MAX PREP when I run that tire, of course.
I see no reason you couldn't hook on that. I have run low 9s on the 315 and Jon has been in the 8s. The DBR i would think hooks better then the street r
