IC Chiller and 15" conversion
rookerrobert
Ridgeland
SC
2016 hellcat A8 and 2016 M6
Well I wanted as long as I could and was hoping to do the work myself but you younger will understand one your want to and health will make things change. So now Allpar is doing the chiller and the conversion for me and I know it's in good hands. I'm hoping for some good results.....lol I ran my car last year about this same time and went 9.83@ 140 and that running mt 315/50/17 and no Ic Chiller. I'm hoping with the IC Chiller and the 15" 275/60/15" it'll do a little better at least more consistent!!
Chiller will definitely help
Allpar did my chiller in spring 2023 with a laundry list of other work.
If you look on IC Chiller's site under the installs/testimonials...that PCP charger? That's mine. Lol.
It's been thru the ringers in 1.5 seasons. Lost all the freon at the track in late 2023. Fought thru charging it myself just to not even make HRDW2023. Came back in 2024 and ran. 10.2296 average for the week with all passes between 10.17 and 10.28 so I'd say pretty damn consistent.
Allpar is good people in my book.
Just remember, if you ran those numbers in low or negative DA, chiller won’t make you faster. It’ll make your car more consistent regardless of the weather
rookerrobert
rookerrobert
Ridgeland
SC
consistent is good also....I do know now that the Allpar installed the chiller thats got to help.Now I just hope the 275's 15" will also. And it was 85degrees outside.
I'm about 10* warmer than that best case.
That's chilly.
That’s cold! I can get that low with the drag valve on
Why are you doing small tire with the 15s?
rookerrobert
rookerrobert
Ridgeland
SC
because I couldn't get the the m/t et street drag radial pro in 17".....but I thought the 275 would be enough but if not I'll go to 315. I know now the track is good my 315r's with 18lbs. I can can dead hook well almost I had scanned it and it does have little spin
275 is if you’re running in a small tire class PERIOD. No other reason to run a 275 tire. Return them.
rookerrobert
rookerrobert
Ridgeland
SC
WE do have some of the race's around here where you run the 275 though
rookerrobert
rookerrobert
Ridgeland
SC
But I'm still going to get the 315 anyway in a week or 2 just in case
