Is a RE blower externally bigger than regular HC blower?
I know the rotors are longer in the RE/Demon blowers, but is it strictly an internal dimension difference? I have never had the two side by side to see, or measured either.
Subscribed
Well??
I had both on the bench side by side . The difference is made up in the snout . The exterior dimensions are the same
But inside could be a goober smoocher of a diderence.
kgrencer
Ridgefield
2019 WBRE F8 Green
Thanks guys. I was wondering the same thing.
So they move the bearings up further into the snout (different casting) and extend the rotors a little more forward? But keeping all pulley alignments the same? Does the rotor machining extend into the snout and also becoming part of the blower or is rotor machining still confined to the case/head?
Thanks a bunch @Hpindy.
The main rotor case is 1.1 inch longer ( I think that's what they said ) the snout is different from the 2.4L . The drive pins on the 2.4L stick out and the drive pins on the 2.7L are receded in to the snout .
Excellent description and info. Nooow it makes sense in my tiny mind. Thanks James.
Tony.
Tony.
I wish I had of taken more pictures but I was to focused on getting that bad on my car lol
Suwanee
Here’s a picture of 2.7 snout and bearing plate that I got from Brett @Jokers
07F910A0-58E0-4D73-8E3F-19B101A08B4B.jpeg BB151C53-92AA-4B75-B0C5-1BF346B19475.jpeg
Matt someone with an SRT
Newtown
Looking at them side by side from a few feet away with hoods open you can’t see any difference on exterior dimensions. I was expecting the RE blower to look noticeably larger but it’s just as Indy said.
Latest Forum Posts
