Is there someone who will do a "good" package and ship it?
Grape Ape
Braselton
oilburner
coboconk
Your setup is exactly what I’m after. What front tires are you running? Beefcake Racing has a good site...I’m definitely interested.
M&H racemasters
DaveB
DaveB
Penhold
Thread Starter #25
Couple more questions...gonna pull the trigger nearer to Black Friday....
Front tires: 26” or 28”? Pretty sure I’m going to go with the Sportsman.
Rear tires: ET Street R’s or SS? I do plan to street cruise with these tires. Long trips will get the factory rims and tires.
TPMS: do you need to have them reset every time you swap tires? If you don’t run them does the car ding at you ceaselessly?
28" fronts along with 28" in back. Street R's
TPMS won't ding at you but will show up on the dash every time you start the car. If you are only using them for the track you could go without them. Problem is if you do buy them and air your tires down, it will tell you low air pressure anyway
DaveB
DaveB
Penhold
Thread Starter #27
Gracias!
Purerock105
Reno
NV
I'm just here for the funnies@1971demon. 😂
No response yet, so I'm guessing from the Intel here, he lost his glasses and can't see the keyboard for a witty retort. 😜😁
What he said^^^^^
For what it is worth, I changed my settings with AlfaOBD program to lowest setting...think it was 26psi min before nannies would start their thing, it also allows you to change size of tire circumference to correct speedo reading. This was changing to Hoosier 325/45/18 DR2 with 18X10 Bogarts. They are much taller than the 28's most run.
Beefcake is good.
Try Paul @ PK Auto too. He might be able to do something. I know the prices are damn decent and my set of 2 arrived 100% ready to go. Zero vibration til at least 161mph. I dont know what that is in syrups per moose like you guys use.
tkracing1
Bay Area
2017 challenger
Beefcake is good.
I agree... 2 great choices.
DaveB
DaveB
Penhold
Thread Starter #33
Another question: hub centric rings or no? Reading on old site, seemed to be the consensus that they were required. Our hubs are 71.5mm correct? It appears the Racestar Drag Star wheels have a 77.98mm hub hole. I can't seem to see any rings in this size range....
The forgestar doesn't require that ring.
