Live action from FUMANCHU182.
Would make a good spare to get someone home from the track if they break, but I would definitely get it rebalanced. For an A8 challenger
Thread Starter #1,342
on the seventh day @Jon-MooredPerformanceLLC said make a rip… the new driveshaft is putting it down
I would definitely take it! Need a spare badly
Thread Starter #1,344
Was putting axles in, decided to service diff as well. Car feels way different in a good way. Drivers side axle was showing wear and tear.
23366A21-76AC-461D-9B0F-D8E361229DB3.jpeg 39F97721-0654-458A-8A12-515CBF2DF87D.jpeg
then to my delight learned the trailer would clear the driveway slope due to it being flat. I thinking I could get used to this bougie life!
66403363-796F-45B8-BA91-BF446A5A4585.jpeg EAA5FE60-F640-44EF-8FEC-3C4DE2E361AA.jpeg
View attachment 100894 View attachment 100895
View attachment 100896 View attachment 100897
Nice! Looking good on the trailer! Get used to your garage smelling like gear oil for a month lol
Thread Starter #1,346
LOL, I learned that lesson already, I went to my friends shop and borrowed his lift.
I just brought my drain pan back inside been sitting in the yard for few weeks airing out after brake clean and degreaser lol. Worst smelling stuff ever. Changed it a few months ago and then topped it off again a little while back
gear oil is an acquired taste ;)
Demonic Cat
Mid
RI
Friction modifier additive Is the worst I had a small bottle of it say 8 oz many years back even if you don’t spill a drop and throw the bottle out it will haunt your garage form months, cross between cat piss and gear oil be the nasty smell.
Thread Starter #1,350
Well I have an hour and a half ride home. Who wants to guess what broke. Ill check responses when I get home. @jonx96 cant respond he already knows.
Diff
Bank account.
Axles again, latest GForce axels are failing for many.
Not a problem broski. Start of pull: 62.6
End of pull: 87.8
Keep in mind air charge temps start to pull timing based on the following values in the tune:
You could move Part Throttle Ref IAT to 999 and it would never pull timing...
Didn’t you upgrade to triple pumps? Pump DC 89%, FP 79/80 psi, Or is that how it works on the control setup you’re using?
Either that or the DS again?
I’m going with axles. Those currently seem to be a problem.
Hmmmmm, mines been going broke since I bought this addiction lol
driveshaft. Those axles are pretty stout
are the new DSS axles the way to go now?
Thread Starter #1,360
winner winner chicken dinner, at the top end of the run she was fine, went to turn right to the return road and it was crunchy as fuck
would rather spend it before it turns into useless paper thanks to sniffy joe
mine will be replaced if so, just put them in
This is how it is, pump 1 is going hard but the computer don't know about 2/3
This also could be at play but I know what this is like and was able to drive to the trailer.
I don't think its them but well know soon
see notes above also may be at play.
car was unloaded, trailer is parked for the next few hours will be reviewing footage and the logs!
