Standard vs widebody vs Demon axles
Corona
I'm sure this has been discussed a lot.
Is there any fitment difference between the standard Challenger Hellcat, wide body, and Demon axles?
My 2016 standard Challenger Hellcat has a torn boot on an axle and is spraying grease under the car. The dealership tells me I have to replace the whole axle. OK. If so, I was interested in putting sturdier Demon/Redeye axles on the car. There is a bunch of conflicting info out there about spline count differences reference compatibility.
I've sourced the OEM Demon/Redeye axles. I just need to confirm "bolt on" status before I pull the trigger on the purchase.
Can I just bolt on Demon/Redeye axles on my standard body car?
Is there any difference between the standard body and wide body axles?
Is there anything else I should be aware of putting Demon/Redeye axles on my stock Hellcat?
Thanks!
Yes, the RE axles fit, I’ve ran them on my 16 M6 NB Challenger Hellcat. Spine count difference is in the Axle bar ends into the CV’s not spine count into the diff or wheel hub. Just be sure you have tone rings on the replacement axels or you’ll be taking them back out to put them on.
N
Corona
Thank you.
No difference between standard body axles and wide body axles?
Thank you.
I’ve heard the wide bodies got the red eye axles, but a dealer told me otherwise. There is a strength difference between Hellcat and red eye/demon axles though. I have a picture somewhere on my phone with standard axles versus redeye axles side-by-side. I’ll see if I can find it and post it.
Octanewide
House of power
The info I got from Steve White motors told me Demon axles are the same for my 2018 widebody Challenger Hellcat.
ps 53010848AC & 53010849AC
Thank you.
None. Why do you think they are different?
Is your car lowered at all?
sc4.6
Port Stanley
Challenger Redeye
Widebody cars have the same axles as Redeye/Demon. I picked up a set of low mile Widebody Hellcat axles to keep as a spare set, they are the same part numbers as my stock Redeye axles. Standard and Widebody axles are all interchangeable, but the standard body Hellcats have weaker axles than Widebody Hellcats and all Redeyes.
N
Corona
No, it's not lowered. Bone stock.
I just want to make sure wide body axles are not...well..."wider" than standard.
It would suck to have them installed on a standard body car and find the tires bulging out past the wheel wells.
There is a lot of conflicting info out there.
Thanks!
N
Corona
That would be helpful. Thank you.
