Tire problems, part the third
So, my friends' shop and I spent 4 hours changing tires yesterday. Yes, 4 hours. Took the defective OEM Pirellis off and put the new Pirellis on (sourced from a major retailer/warehouser, which shall remain nameless). Defectives come off easily, but the new All Seasons won't seat on either wheel. The inside would pop right away, but the outside would snug up under the lip and you'd get a 3" section that wouldn't seat. Mallet, strap, spinning tire on wheel, etc... nothing worked. After I took off for a meeting they ran the wheels and tires over to a shop with a cage and high pressure air and it seated perfectly.
So, take the car out and there is still shake over 80. Different shake, but still shake. Sending these tires back too, replacing with PS4S since these two will only be up front anyway. If the Michelins shake too, then we know its something else. I really went over the suspension, steering rack, etc.... with a fine toothed comb yesterday and so did they and still didn't see any damage that would account for the shake from that near blow out / lathe to the tire tread incident.
On the wheels, have not sent the ones that are out of round out to be machined yet. No time.
It can be risky to over inflate too much. My guess is that there wasn't enough tire lube, or the wrong kind was used.
Could it be the wheels?
AeroF16
Phoenix
I have brand new Pirelli all seasons that shake too. Not sure how to "send them back" because I purchased from an out of state dealer when I was in a bit of a time crunch.
I thought I was crazy because I had 2 sets of wheels/tires doing almost the same exact thing (PS4Ss and Pirelli A/S), though the Pirellis were always much worse.
I'm sure you've seen my thread but, the solution to my PS4Ss problem was 2 new tires. The car drives like a dream again.
It was really really slick... even added a little water at one point. Never seen anything like it.
it happens sometimes with the Pirelli's it seems. The ones on the Vipers routinely take 80+PSI to seat the bead. One guy I think had to go to 90
That's what we were told too, that we weren't going high enough. while I was around we were maxing at like 40 (yes, we're conservative) so hence to the cage at the other shop
These wheels were a tiny tiny bit out of round, not perfect. But nothing that would produce any vibration in my experience. We'll see when the Michelins get here. As noted, that's the telling test, if the PS4S do it, then it's the wheel or something about the rotating assembly.
The Max
Toms River
After reading about your tire issues, don't think I will ever change my tires!
Hopefully you resolve and curious to see what is causing the vibration.
Wouldn't drive em in the rain when the tread is gone...
Tires ain't perty but not to shake. Interesting.
Kwalski
SALISBURY
Would it be possible to check the wheel on the balance machine with no tire mounted? Mark the area where the most weight is needed, this should rule out a wheel issue. Out of curiosity, are the match mounting (heavy mark on tire to valve stem)?
Yes, a Hunter has the option to measure the bare rim, and obviously it can also be balanced without a tire.
The wheel can also be measure with a tire mounted, as long as there are no weights in the way, and the face of the wheel's design allows it.
That method isn't as good as measuring the bare rim, which measure the area where the tire seats.
Generally a tire should be mounted with the correct "ring" on the sidewall positioned at the valve stem.
The problem is that not all tire manufacturers use the same colors for indicating the same things.
Kwalski
SALISBURY
I would imagine that most suppliers list this information on their webpage, at least I would hope so. I know that when I get tires mounted, I always ask to have them matched, just not sure if it goes unasked, does the installer practice this as part of the normal mounting procedure? My guess is that they do not.
A good tire shop should know to do it. If not, it only takes a few seconds to look at the finished product and see if they did it right.
Of course, it sounds like many shops don't even know how to utilize the balancer to its fullest in the first place.
OEM size PS4S arrived earlier this week; waiting on the M/T ET Street S/Ss to arrive, test the wheels without tires, slap them on, and return the latest set of OEM Pirelli all seasons.
Commentary: When I grabbed these PS4S's I immediately noticed that these seemed softer and more supple than this set of Pirelli's we are sending back, but also far softer and more supple than the PS4S's I put on the car when they were first introduced (and sent back because of the strange behaviour I experienced with them as rears)
Leaving town for the rockies. all you others travelling, be safe, and to all, hope you have a relaxing vacation.
Keeping my fingers crossed for you. I am out running errands and having fun with them. Today with the air continuing in dream condition the cars are running so well. They want to audibly squeal which is unusual. Makes it more fun modulating it, which is not taking much today!
So, the PS4Ss went on this morning, along with the new MT ET Street SSs, and the car is perfect. Rock solid up to low 110s (should hold true higher up too, by my experience; bad weather and traffic prevented higher testing). Offending Pirelli POS tires going back for full refund. I've always used Michellins and I'll keep doing that. That is 6 bad Pirellis from 2 different suppliers.
You could tell just by looking at it the rubber on the Hunter as it rotated.
You traveling through he Rockies with MT Street’s in the back?
Thread Starter #19
lol, no. For that I take the Expedition EL 4x4. Sometimes both it and the 2 wheel drive (wife/fancy) Expedition EL. Just the "driveway" leading to the cabin is intimidating for some. Had wood cutter bring in 2 cords of wood (he stacked one, had him dump the rest so we could do the other) and he said "you aren't kidding that drive is steep. That's STEEP." I have no doubt the Charger could make it without difficulty, but unless its summer I'm not taking it out there.
The old MTs were definitely done. Not as bad as the previous set, that had wire peeking in places but still ready to get off the car.
Thread Starter #20
Ohhhhhh, so smooth. It's silly I know, but I always feel happy with new tires on the car, like it's Christmas and I'm 8 or something.
