HangZhou
China
Will a cylinder misfire be indicated on the display, or can it only be read via OBD? Just now on the road, after a hard acceleration and then slowing back to 50 mph (in 8th gear), there was intermittent shaking, similar to a sudden loss of engine power. The car's mileage is 17,300 miles, using 91# gasoline. Do I need to check the spark plugs? Thank you all.:coffee:
Did it then go back to full power....check engine lights???
HangZhou
China
The check engine light has been staying on—this is an old issue. The fault code only shows U113F. After pulling over at a service area, restarting, and driving smoothly for a while, the symptom disappeared. Very strange. (BTW, my car makes a very subtle rubber-like rubbing sound at low speeds, both when moving forward and reversing. We tried to locate the source of the sound; from the driver’s seat, it seems to come from the right side, but the technician in the passenger seat heard it from the left. Just now, this rubbing sound became very loud, but after driving on the highway and returning to the repair shop, the sound disappeared again.)o_O
HangZhou
China
Can you see the video I posted? There is a very obvious rubber friction sound in the middle.
http://xhslink.com/o/24ozp0a7rvP
06SRT10NR
Knobnation
I see the video, but no audio
HangZhou
China
The friction noise occurs around the 2–9 second mark in the video. Please pay attention to the speaker icon in the lower right corner—if it's muted, click it to turn the volume all the way up. If possible, using headphones is recommended, as the noise might be difficult to hear clearly through speakers. Thank you sir.[shakehands]
Slimcat
Jacksonville
NC
2016 Challenger SRT HC
I see and hear your video. I do not hear the sound you are talking about. Try taking the car to a empty parking lot, an doing very small tight figure 8"s. See if you hear it doing that.
Empty parking lot in China???...(like tryin to find awesome lasagna)..[giggle][giggle][giggle][tongue]
HangZhou
China
I will give this method a try and attempt to record the noise more clearly. Thank you very much.
HangZhou
China
In fact, there are quite a lot of such parking lots. They are usually located far from residential areas, so they are less frequently parked in. More often, those who gather there are automotive enthusiasts.[hihi][histerical]
Slimcat
Jacksonville
NC
I removed the speaker box from the spare tire area. Found 10 years of dirt under there, it's spotless now. ;)
Getting real detailed in my inspection and detailing under it now. Pulled a small metric fine thread bolt from the back of the AAD Toe arms. Realized the ignorant asshole who worked on it last spring (not my usual dealer, and will never see it again), somehow decided to eliminate the two bottom of them. I need to go buy a couple new ones and re-detail the signal/control wiring. They had to replace one side of the assembly, after the wheel chewed it up on the right side, AND they had to also replace my front AAD control arms because the idiot stripped one of the bolts up there too. Pictures next week after I get those things clean and detailed again.
23 Challenger Demon 170
Unfortunately you’re stuck with more idiots than a real mechanic. It’s tuff when you’re super picky.
I just did not want to tackle the darn springs myself. I had the correct dealer and individual put the OEM stuff back. That is the same guy who installed ALL the AAD members. Then the same guy and me checked the alignment. I think after I do this minor little thing, I can sign off on the mechanical parts. Then I’ll clean it up and take it to the courses. I need to get out some of my motorcycle detailing stuff. These AAD arms are tough with the impressions that apparently catch any and all overspray from the wheel washing.
Road America first week of May is a definite start.
45-70govt
Ghetto
Only you post pics of an issue AFTER detailing said components. ---Legend!
Funny. Let me get it done, I promise a b4 and after. The darn arm is filthy.
Son got in a minor accident so his trucks in the shop and barrowing my mine. So, I've been forced to drive this damn hellcat all week... Oh the agony! :p Seriously though, having an excellent time with this old m6! Probably put more miles the week than all last year.
TorRedHellgato
New York
2020 Dodge Charger Hellcat
Maybe wait for spring instead, in case it happens again?
With all this snow thats incoming, it wont be until spring anyways lol
Stork arrived today! Happy to see the ink is still on the DR's!
CPO Super stock
westminster
2021 Superstock
Congrats
