Forged Redeye Engine Failure :( Why????
Thread Starter #41
If it was an oiling issue then the cause is not with the main caps. What do the journals on the crank look like. What do the oiling ports on the journals on the crank look like? The caps have one purpose, that is to keep the crank attached. That's it. What do the bearing journals look like?
The oiling issue was because with the cap pushed off it seat the crush on the bearing shells was not there any more and the main bearing shell rotated just enough to close off oiling to the journal and up to the rod journal and caused a rod failure. If the studs would have been strong enough to keep the main caps in place none of that would have happened. Root cause was main studs did not hold caps down tight and allowed other things to happen because of that. The witness marks on the caps says it all, they were doing that for a bit before things progressed to failure. They were ok at 1000 and 1300 to the tire but did not like 1500 to the tire. The purpose of this thread was to point out the weakness of this engine that lead to failure was main studs due to material type were not up to the power level being made.
Thread Starter #42
Maybe it was a material rod failure. It just let go, kaboom. Possible
Boostline rods do not usually fail without reason, they are pretty beefy rods made from some of the best steel you can get.
Thread Starter #43
Journal on the crank looked fine, journal on the rod did not, was starved of oil due to the bearing rotating about 30 degrees from where it should have been.
stonewall
Conway
AR
2017 Dodge Hellcat Challenger
How much time was put on it at 1500hp? I'm trying to figure out how long it took to do the damage to the caps. we are assuming that it all happened at 1500hp because that is where it finally failed. but do we know it had not already incurred damage at lower numbers as well. I have built many engines, Not high end performers like this. but the principle is the same. the caps especially the rear main, looked nearly new in the bearing saddle, with know ride marks of the shell like the others have. which makes sense as the load was probably more on it under load and would have stretched it first I would think. but as you stated the failure was when the shell spun, the clearance could have been excessive long before the tang gave out and let it slip.
Main bearing spun, blocked off oil to the main bearing, starved crank and rod of oil. No heat in the cap, no sign of the bearing spinning on the cap. What am I missing? Can you show a picture of the rod that failed from lack of oil?
Thread Starter #46
Bearing only moved about 30 degrees, just enough to move the oil inlet slot and close itself off, did not fully rotate and spin. that crank journal had enough oil to lube itself enough but nothing up to the rod. The rod somehow side welded itself to the crank and spun with the crank and sheared itself off on the block and then spun with the crank like it was a welded on balance weight. Weirdest failure ever!, windowed the block, did not even damage the crank visually but it was not reused. B094D90C-AA86-44C1-B367-12BB5BEB8063.jpeg IMG_7729.jpeg E3EB8185-3681-4CF8-AFA9-C7D04F1C44A7.jpeg 4CBE9659-73B4-4F17-8109-AF4FB4191A54.jpeg
Thread Starter #47
Yes, with the caps pushed open the vibration from the caps unseating and then seating themselves hundreds of times a second it’s thought vibration and oil pressure hydraulically loosened the bearing shells in the bore and they started to rotate and blocked off oil path from the oil galley. It did not take long, failed on the Dyno during the use all boost made 1500+ dyno tuning session.
Spoolin
Sellersburg
IN
2019 Challenger WB Hellcat
You were using 260k+psi none tapered studs, correct? Better than L19, which can corrode over time.
Very odd that they stretched beyond their clamping force, unless they weren't actually torqued properly with good lube in the proper areas.
23 Challenger Demon 170
Reminds me of counterfeit parts that was a big problem in the airline business.
Thread Starter #50
That engine had standard grade ARP 8740 material studs in it, they are like 190-200,000 psi tensile strength. Engine needed better is the moral of this thread.
Its Trumps fault
I've proven the boostline rods to be the weak link in 2 different engines, to the point they made a new version of the rod due to failures. Both my demon engines had the same crank walk marks on the main caps as well.
Thread Starter #53
Yes, agree, Boost line are not my favorite rods either. My preference would be Crowler or Callies super duty rods. But that cap walk witness marks was not from the rods, that’s indicative of the main studs not being up to holding up to the cylinder pressure task. Did you upgrade your studs beyond the ARP 8740 or are you still using them?
Very interesting case study - thanks for sharing! I don't have a dog in the hunt, but the thing I have been struggling with is that there are engines out there running a fair ways north of 1500, that were dyno tested and then placed on the race track in fast cars that seem to be humming along just fine, and I do not believe they have any super-alloy main fasteners. The obvious evidence of cap movement is in plain view, but I question the ARP studs as being THE root cause on this one. To me, something else was going on that was causing the bottom-end loads to be non-commensurate with the power level. And yes, "no thanks" to the Chinese Boostline rods. Somebody with that much coin in the build should be using a better rod, period.
catdad
Lake City
#55
@16GoManGoHC2 I remember in the SRT4 days that ARP made head studs and they were not the correct length and caused the incorrect clamp load. Their fix was a thicker washer. Is there ample threads on those studs to get the correct torque without bottoming out on the stud?
Thread Starter #56
Yes, studs were fine dimensions wise. Engine builders like MMX and Steve White Motors and a few others recommend after 1200 wheel better studs should be used and recommend better caps along with better studs after 1400 to the tire, 1500 being the tipping point to either mod the block to 4 bolt caps on 2 3 and 4 caps and better yet a better block designed for 4 bolt caps on all 5 main journals. 1500 to the tire is getting up there!
This engine was stroked to 426 cubes with twin turbos with boost in the 30’s with a high lift cam and very open exhaust, it was capable of making a bunch of juice! Replacement engine is planned to be a 4 bolt block this time with different rods, I recommended Crowler I beam rods, I know a few guys making north of 1500 wheel with them (on 4 bolt aluminum blocks)
Switched to MMX and the Dart blocks for my engines. no more issues.
