Hellcat down
go to Tappeds site. The inline filter is for IF you remove the in tank filter sock on the passenger side Jet pump, or run a return system where you’re running at 100% pdc all the time
I don't have to. The general consensus within the race community as a whole is to run a 10 micron filter. Not paper.
It's common sense. But don't post that it's not needed.
This is about filtering fuel, not the fuel system.
Why does direct connection have 2 inline filters in their kit?
For a return system with no internal fuel pump socks. The stock socks aren’t paper. The mat in the fuel cell degrades over time. You don’t have that in a stock tank and if you’re running socks on your pumps. I bet you still have socks on yours, so the micron filter is an additional restriction if you’re not replacing your in tank socks
I'm not talking about that.
I'm sure that racetrac e85 is pure as the driven snow...or e50. Whatever it is.
I'm just fucking with you. I really don't care...
Bowlerguy92
Bowlerguy92
Thread Starter #224
Like Jon said, I'm trying to get clarity on the notes the shop received from the testing facility. They are all free flowing now, it sounds like while being tested they may have begun to function again. I don't think a formal repair to these was ever made, or at least not one that I authorized or paid for. Trying to see what other notes or observations were sent over.
@fumanchu182 As much as I'd like to clean these up and reuse them, it seems ridiculous to put these back into a brand new motor knowing what could happen again. I'll probably bite the bullet and add ID 1050's to my long shopping list for this project. I appreciate your offer though!
And, yes, for the record I'm running 93 only. Mixed with Torco for track use. This car has never seen a drop of E85. We do not have it here in NH.
Bowlerguy92
Bowlerguy92
Thread Starter #225
New custom long block from @Hatermkr is in NH at the shop safe and sound. Thitek ported and polished heads, big CamMotion cam from @Jon-MooredPerformanceLLC and upgraded almost everything else, very little left that is stock. Long tubes are arriving at ATP Wrap today for custom inconel heat shielding. Once that is complete, the shop I'm using should be ready to receive my car back and begin work on the rebuild. Probably the first half of February to be back up and running. It's been a long 83 days....not that I'm counting.
Hatermkr
West bend
2016 helldemon
Let
Let it eat
But then you have a problem and burn a piston. These shortcuts have never made any sense to me. Oh well.
so someone thinks you need to run one and everyone not is taking a short cut. Fuel pumps have filters on them already
10 microns?
Hatermkr
West bend
2016 helldemon
Where is this filter you speak of on a hellcat??
you your saying the sock 🧦 on the pump that is not a filter
injectors have a filter on them also. Than how does things get through to make an injector dirty.
It's added into the fuel system.
The sock on the pump is not fine enough.
The one in your car is 10 microns? Got a pic and a link to it?
I want to see dirty injector baskets, the only direct on/in mine are from blow by
One I was looking at is washable metal mesh
16 an is huge. Who did the install? Do you know what fittings and hose they used? Where did you mount it at?
Anyway, when I get my engine built I’ll run one. Might as well
Your intank filter sock is 100 microns.
My guy installed it when the dual pumps were put in. I don't work on shit anymore. I have no patience.
Hatermkr
West bend
2016 helldemon
Yes I have one also. With my triple pump.
Hey BG, I hope you will do something to avoid salt spraying your car moving it back to the shop. I don't even want to use my alum trailer in this crap!
If it were me, I wouldn't worry about it, I'll be dead or in the home before it rusts through. But you are a young guy and might want to keep it nice for many years to come. And you have a daughter who may want it! :)
