How-To: Rebuild Front Two Piece Rotors.
Tools required:
10mm Torx socket.
10mm deep socket.
2 ratchets.
262 Loc-Tite, or Permatex Orange.
In. Oz. torque wrench.
Steel wire brush.
Brembo H-Bobbin hardware kit.
Black Spray Paint (optional)
To begin with, disassemble each rotor, removing the hat, from the disk. You will need both ratchets, with Torx and 10mm deep socket.
My rotors were apparently built on a Friday afternoon. If my hardware configuration looks different, than yours, make a note and re-assemble the way yours are built. That's what I did.
Once the hat is separated, from the disk, you will want to remove the H-bobbins and spring clips. The spring clips slide right out.
I wire brushed the hat and painted it.
While that dried, I took a wire brush, to the H-Bobbins, to remove all the brake dust.
Bob
Thread Starter #2
Once the hat was dry, I installed new spring clips and the cleaned up H-Bobbins.
Once complete, mount the hat, to the disk.
Use a small amount of thread lock, on the first few threads, of the bolts. Tighten them, in crosswise pattern, to 65 Inch Pounds. DO NOT OVERTIGHTEN THEM.
Now, you're finished and can re-mount, to the car.
Hope this helps.
Bob
Great write up. Where did you get the hardware kit?
AeroF16
Nice work, Bob. Nothing like the satisfaction of a job well done!
Believe it, or not... eBay.
Just replaced the H-bobbin retaining springs. I had 5 of them fail, as detailed in another thread.
Bob
Prange
no longer in Chicago
2021 Charger Scat Pack
Beautiful job. Thanks.
DMNkilr
Doctor
Highlands Ranch
2016 Hellcat
great write-up and nice work!
Great job, Bob! Very helpful post.
@WIKI
Bob
MiHiHemi
Parker
2015 Challenger SRT 426
Interesting. My nuts are the other way around...and no jokes guys :ROFLMAO:
Yeah. I think I remarked that I've seen both ways.
I just rebuilt the way mine were.
Bob
Wantagh
2021 Durango Tow-N-Go
Hey there mihihemi just seeing this thread and I'm rebuilding my front brakes but I'm having a hard time finding just the rotors by themselves. Love your design over the plain old slotted any chance you have a model or part number or brand? Any help would be greatly appreciated. Thanks Dan
MiHiHemi
Parker
If you go DBA, here’s the nut torque info. It’s easy to do yourself. Just a little tedious and I used a bit of blue Loctite. They also send along new nuts. Nice thing about DBA is they’re non-directional so you can’t mess up which side you install them on.
Hope this helps.
Bob
Did you turn the rotors?
Did wife catch you drifting spray paint over the awning and metal frame? ;)
My input on the subject is that there seems to be a torque discrepancy. However, on hardware like this, different hardware can make a notable difference, so keep that in mind.
I've seen values from 65lb-in to 100lb-in and even other values as well.
No and no.
LOL
M6 is the size of course, which grade is critical, and you don't want to use 100% either.
CDT is currently using Grade 10.9 and recommending 120lb-in, but this is not directly applicable to the above information.
MiHiHemi
Parker
The torque info I used was supplied by DBA. 13 Nm = 115 inch/lb or 9.5 ft/lb.
McLovin
Syracuse
Bob
Happen to have a link by chance?
Looked for it yesterday, but came up empty....
