Staggered Set-up 20x9.5 and 20x11 - 275/40 and 315/35
S
Skrelnik
Fairfield
Thread Starter #21
I’m running a 315 tire in the rear on a 11 inch replica with no issues on my Challenger! It looks badass with that staggered look.315/35/20 traction is awesome. View attachment 8917 View attachment 8918 View attachment 8919 View attachment 8920 View attachment 8921 View attachment 8922 View attachment 8923 View attachment 8924
Great pics, thanks for sharing. What brand of wheel is that, and do you happen to know the offset.
Primetime Hellcat 17
2017 challenger Hellcat
Who's rims you using and what offset? Those are exact replicas of my RE rims and would match perfect. Also those tires are Nitto's correct? @Blkout, as I have read elsewhere, said they run a little narrow so maybe that's why the success. BTW don't want to steal the thread but how's the King Kong cam doin'?
PK Auto Design makes them. They were a vendor on the other HC forum. There located in SoCal. I believe it is a 21 off set I’m not sure though.
Ya the tires are Nitto NTO5’s.
The next tire will be the Mickey Thompson ‘s 305/35/20 DR for abit better traction on the street with the new power level I’m at.
The Cam is awesome. I’m glad I did it. Thanks for asking. Also Blkout is correct. All 315’s tires are different in diameter. Call Paul at PK Auto Design he knows everything about the challenger and charger wheel and tire combo in running 315’s. There is always a 3mm spacer option available too.
Hope this helps....
1 more thing. If anyone is gonna run some 11inch wheels and some 315’s get the Mopar splash guards your gonna need them.
Blkout
Warner Robins
Alot of tire stuffed in there! Nice.
Here's a 335 on the rear
And a comparison of a stock 275/40, a 305/35, and a 335/30.
S
Skrelnik
Fairfield
Thread Starter #25
Hope this helps....
Very informative post here and pretty much my game plan. I was in touch with Paul about using a 20x11 with 315, but there are numerous threads that say otherwise, and rubbing is a guarantee. I don't mind if the tire sticks out from the fender by a quarter inch, but my concern is if on a dip, or hit a bump, will the tire hit the fender, or is the stock bumpstop set such that it will not hit?
My only concern with the 305 is that the rolling diameter is a full percent off from the 275, so while the 305 seems like the obvious choice that is the reason I am seeking more answers as I am by no means am expert on this topic.
What is the rim width and offset that gets that 335 in there. I know you have the Philips flares, but they're not rubbing on the inside? or hitting the quarter panel rear wheelwell lip? I love a fat ass and those 335's look like Jaylo wear'n a thong and lettin' the fat show. LOL
Blkout
Warner Robins
I don't know the offset but the rim width is 20x11.5". I had Paul at PK Auto Design build them, I just told him how much extra space the flares added to the width of the car and he did the math. And, they're not rubbing on the inside or hitting the quarter panel lip.
Blkout
Warner Robins
The tire will not hit the fender, that much I can guarantee.
why2kmax
12 Second Best E/T
Shrewsbury
V
The 305 difference is not an issue. the sensor at the rear/driveshaft compensates so no speedo issue and seemingly no ABS issues either. the height diff is there but is barely noticeable.
JRabq
Heres my 2017 Challenger HC experience.
Bought PKAD HR5's 10.5 ×20" with their standard +25 offset for the rears.
I chose Continental ECS 305/35/20s
First install: slight rub inner plastic liner.
Second install after heat gun: still slight rub
Third install after trimming liner with blade:
No rub, but tire within knatsass of metal on
Inner wheel wheel. Hmmm
Fourth install with above adjustments and 1/8"
spacer. All good, no problems.
Talked to Paul PKAD. Cont ECSs tend to run a bit larger than other same size tires. Not all Challenger wheel wells exactly the same. Definitely less room than Charger. No worries using 3mm spacer.
Overall totally happy with final outcome. How people fit 315 or larger without sticking out beyond fender...no idea!
Blkout
Warner Robins
Yep, I would always a recommend a 3mm spacer first before cutting the car. That will usually do the trick.
My 11.5 x 20 Triumph's were designed by Bismarck @TRIUMPH , so have no idea on offset. Asked him if he could build me a wheel that would work with the flares and not require any inner mods.
Yep.
S
Skrelnik
Fairfield
Thread Starter #33
Great call, I have been looking at tire specs for differences, and noticed some are different sizes due to rounding. I also own a Wrangler and have a similar issue, certain tire brands run bigger than others, and will then rub the fender lip.
Sounds like I need to do my homework on tires and then make a call to Paul at PK to see what the best pairing would be for my situation.
S
Skrelnik
Fairfield
Thread Starter #34
Are you aware of any issues from the tire sticking out of the wheel well/fender, or is it mainly a cosmetic concern? Thanks for the replies, you put me in a much better position to make an educated choice on the set-up.
D5DA4C57-09DB-4155-B3B7-32C7E3BFCA8B.jpeg 3ADD4CC6-491B-49E5-9795-829F1766B3D6.jpeg A8976EB5-7E24-4C38-813D-AA6C61856DD4.jpeg 2B5E941F-1653-41D1-A351-A824BD0934C9.jpeg 5666361E-0EF4-4042-88B4-752C8CC34333.jpeg
Here is a few more pics with the 315’s on a 11 inch wheel.
Blkout
Warner Robins
Cosmetic and it could throw more debris on the car
S
Skrelnik
Fairfield
Thread Starter #37
Thank you for all the replies! Not a big deal as we already have splash guards, but we can throw some PPF on the rear quarter panels to give a little more help.
S
Skrelnik
Fairfield
Thread Starter #38
06SRT10NR
Knobnation
2015 Challenger Hellcat M6
much like widths varying from tire to tire, you'll also find a range of diameters. tallest 305/35/20 I'v found are M&H Racemasters, sidewall profile is closer to 37%, so within 1/10" of the P0 315/35 or 274/40. will be giving them a shot [on a pair of Biz's works of art] as soon as things dry out around here, and warm up a bit
