Tow package?
I have a 2 door. It's 2 late for a larger garage. The house is built.
Forgot about that. So you already have a good daily driver, and the DRW can sit outside.
Problem solved.
Problem solved.
They all stay inside. DRW will fit. It would be a hassle.
Now that you have sucked all of my personal info out of me, you must work for the FBI?
You need to change your avatar so I can stop feeling sorry for you.
And do consider that a cab & chassis is narrower than a regular pickup DRW.
A SRW is narrower than a DRW. That's common knowledge.
But not so common knowledge is that a C&C is narrower than a pickup, both being DRW.
Also common knowledge is that having two extra rear tires is far better than having two extra doors in the rear.
Well if I decide get into the heavy equipment or house moving business, one will be at the top of my list. But it won't be a 3500...
Well, if you decide on a Furd F350 instead, that's okay.
I do have a wrecker now, remember?
By now you know what my preference is. And not only do I have a significant tow vehicle advantage...there are fewer doors to drag around on the trailer. View attachment 77031
Is it overkill to pull a single car with a 3500? Maybe. But I don't mind the extra safety margin one bit.
Did you get another Challenger? I thought you got rid of it.
No, you remember correctly. That photo was taken before heading to Utah to trade it in.
We no longer have three Granite Challengers. But now two Audi Q5s. One of these days I should make a list of how many "his and hers" we have.
How many Challengers?
We're down to two now.
Off the top of my head, there's also a pair of Ram 3500s, TRXs, and Audi Q5s.
That's in addition to his and hers Can Am Defender Limiteds, JD Gators, Kubota tractors, and Daihatsu HiJets.
"........and a Tunnel Washer in a pear tree........."
Don't forget 2 turtle doves...
IDK about the turtle doves.......but the tunnel washer is true.
He may have finally sold that.
WTF is a tunnel washer?
Yes and no. I sold the Unimog it was mounted on, but still have the actual tunnel washer apparatus.
My latest idea is to mount the hydraulic chainsaw on it, instead of the brush.
Don't worry, David, I'll dig up a photo and post it later. Don't want you to be the only unedumacated member here.
One of these things is not like the others,
One of these things just doesn't belong :unsure:
