- Member ID
- #1248
- Messages
- 60,954
- Reactions
- 212,922
- Likes
- 402
- City
- Middleville
- State
- MI
- Country
- United States
- Vehicle
- 2016 Charger Hellcat
Car related -
So ive been going back n forth thinking about DR’s. Wondering if theyre speed rated/limited. Want the grip down low but wondering about them if I do a high speed run.
Tire manufacturers determine a tire’s capacity for heat and speed using a testing machine. Usually testing is done to meet ECE (Economic Commission for Europe) standards, so the scale is based on kilometers per hour (km/h). A more rigorous test is sometimes done to meet SAE (Society of Automotive Engineers) standards.
- For the ECE test, the tire is properly inflated and mounted on a wheel attached to a testing machine in a room that’s heated to 77 degrees F.
- The tire is pressed against a metal drum with enough pressure to simulate a realistic load.
- Starting at a speed 40 km/h lower than the proposed rating level, the tire is spun for 10-minute increments at higher and higher speeds, until it reaches the target speed.
- The tire spins for 10 minutes at the target speed.
- It’s then removed from the machine and inspected for any failures, like separation of tread components. If it’s intact, it passes the speed rating.
- Sometimes an SUS (step-up speed) test will be added after the tire performs at the target speed rating. Speed is increased until the tire fails.
- If the tire is being tested at the SAE standard, it’s required to run for an hour at target speed in a room heated to 100 degrees.
- Show All
