Pole building size for lift
alright so trying to plan for a pole building to move all of my equipment (junk) into, I’m thinking 30x30 will do the trick with enough room for a small office (closet?). What’s the ceiling height you guys recommend for a full size lift? Thinking 14 but I don’t want it to stick out like a sore thumb. Could I get away with 12? Probably won’t be putting trucks up there. Post up pics of your pole building shops/man caves!
This is all dependent on the size of the lift, I would plan around that. This will determine the depth of the concrete pad that needs to be laid as well.
https://www.bestbuyautoequipment.com/2-Post-Lifts-s/285.htm pick a manufacturer, read the specs and then plan for the building.
It would also help you plan for electrical that needs to be run and everything else.
I have 12' ceilings in my garage that was designed for lifts.
I would recommend the tallest garage door that you can fit so that you can put different things inside.
Build the largest building that you can afford. They're never big enough in the end. My garage is 32x32 and it's too small.
Demonic Cat
Mid
RI
12’ will get it done with some lifts built for that clearance but 14’ is ideal that’s what I will go with when I start my build. Obviously the 14’ cost a bit more To build.
U
That’s disheartening haha was hoping 30x30 would do it..
U
If I get a floor plate one I think 12 will do I’m 6’ tall I want to walk under the car
Looked huge. Not.
Demonic Cat
Mid
RI
Clear span rafters to maximize height clearance.
U
I need space for workbenches car engine crane tool chests lift shelving units
U
My garage now is already 26’ deep so I wonder how big of a difference 4’ really is really just need more width
I have 2 cars, a truck, shelves small atv, tool box, etc. I can't do anything in there unless I move stuff out.
Personally I would like a 60x40. Or a barndominium.
Deano
Law Enforcement
Roy
2019 Challenger WBHC
As for height, I went with15'. The door is 12'. It was more than needed for any car or pickup truck. However, when I got a small motor home that is 9' 6 " high, I had to change to a wall mounted door opener and the MH just does clear the trusses.
U
I just found out what a barndominium was earlier today haha I’d live in it
U
I have a wall mounted door opener in my home garage because I was going to get a max jax lift
Just got home. Here's what it looks like with cars. It's packed. I recommend more width, at the minimum.
Demonic Cat
Mid
RI
Wife wanted to do the bardominium thing and have horses in at the ground level. I countered with fine, ok bardominium it is but with cars in ground level and we won’t call it garage-o-minium just keep barnominuim name. That was the end of that design idea.
U
If I could fit 2 cars in there with enough space for equipment and workbenches I’d be happy haha
You can by using 1 bay for that.
My garage now is already 26’ deep so I wonder how big of a difference 4’ really is...
Right about 15%. Why?
